Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Created ASD template to import robot drawing.
3 REPLIES 3
338 Views, 3 Replies
I reinforced beam and column with Robot and I would like export this reinforcement to ASD with brazilian drawing norms.
Do you know how to create a template in ASD to import the drawing like I would.
Attache : An example of brazilian drawing. beam reinforcement.png
Infact, I would like the negative reinforcement it is placed automaticly under the beam´s form and the positive reinforcement automatic up the beam´s form. I kown that the editing mode put the reinforcement outside of the beam/ column form but I didn´t find how to modify this mode too.
If there are a way to do this, it should be really good.
Thanks for the help.
Regards
3 REPLIES 3
Sorry the possitive reinforcement under the beam and the negative up.
Rafal.Gaweda
I am afraid it is not possible to prepare such template.
Rafal Gaweda
gustavo_c_vasconcellos
Dear EduRJ,
try to use the Italian or French template at ASD.
The Italian one (RBCR_039.dwt) is very similar with the Brazilian.
Gustavo
