Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Crash when opening Load Table or entering Loads module
2 REPLIES 2
372 Views, 2 Replies
Hi All,
RSAP 2013 has suddenly begun to chrash when ever i open the Load Table or try to enter the Loads module. It worked fine one hour and the next i suddenly just didn't. This annoying problem occured first time in the middle of session where i was modelling af slab. First i thougt that maybe my project file was corrupted, but this is not the case since it works fine on other workstations. So I thougt oh it must be a graphicsrelated problem, this was tested by the IT-department that supports the machines, they did not find anything. Then I asked them to uninstall and reinstall RSAP, again without any luck. The problem persists.
I have tried:
- Updating Graphicscard  drivers (Nvidia Quadro K2000M)
- Reinstalling RSAP 2013
- Removing Hardware acceleration
- Deleting windows %Temp%
I have no Idea what to do next. Any help?
Thomas Lade
Structual Engineer
2 REPLIES 2
Rafal.Gaweda
Try:
- delete   cfgusr     folder before next robot start
- set any pdf writer as default printer in windows system
Rafal Gaweda
in reply to: Rafal.Gaweda
Did both at once - It worked!
Thanks!
