Hi All,
RSAP 2013 has suddenly begun to chrash when ever i open the Load Table or try to enter the Loads module. It worked fine one hour and the next i suddenly just didn't. This annoying problem occured first time in the middle of session where i was modelling af slab. First i thougt that maybe my project file was corrupted, but this is not the case since it works fine on other workstations. So I thougt oh it must be a graphicsrelated problem, this was tested by the IT-department that supports the machines, they did not find anything. Then I asked them to uninstall and reinstall RSAP, again without any luck. The problem persists.
I have tried:
- Updating Graphicscard drivers (Nvidia Quadro K2000M)
- Reinstalling RSAP 2013
- Removing Hardware acceleration
- Deleting windows %Temp%
I have no Idea what to do next. Any help?
Thomas Lade
Structual Engineer
Solved by Rafal.Gaweda. Go to Solution.
Try:
- delete cfgusr folder before next robot start
- set any pdf writer as default printer in windows system
