Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Core walls results
4 REPLIES 4
miquel_rodriguez
2138 Views, 4 Replies
Core walls results
I defined core walls onced I introduced the walls, but I can not see the results of core walls in the building results diagram dialog box.
What should I do to see them?
4 REPLIES 4
I guess you have not defined Stories ?
Rafal Gaweda
Thank you,
I defined floors and everything works well.
I had I little bit of trouble with the floor definition because I had to manually assign every element to a floor. Is there a way to assign to a floor a list of specified elements?
Rafal Gaweda
I do not know how to analyze  shear wall
