Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Core Wall Results - Centre of Rigidity Converges on 0,0,0
4 REPLIES 4
C.MacNicol
568 Views, 4 Replies
Please see the attached images for my problem. I have defined 6 separate corewall. When I view the results it appears there is an error in the value for the top 'cut' i.e. storey 11, cut 2 that comes out much larger than the lower values.
When I view the results graphically it shows the centre of rigidity for all the cores converging on point 0,0,0.
What could be the cause of this?
Regards
Chris
4 REPLIES 4
Rafal.Gaweda
in reply to: C.MacNicol
File please.
Rafal Gaweda
C.MacNicol
Is it possible to send this file in a private message? I am setting up a Wetransfer location.
Rafal.Gaweda
Yes, please
Rafal Gaweda
Rafal.Gaweda
in reply to: Rafal.Gaweda
It seems there might be some inaccuracies in panels \ stories definition.
I have defined stories from scratch and corrected geometry of panel 168 using addin from http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Rounding-up-coordinates-API/td-p/3430533/pag...  message 16
Still 2 cores ....
File in PM.
Rafal Gaweda
