Mr Robot,
I am trying to model a multi-storey RC frame building. I have successfully copied several stories as the layout is fairly reptitive, but I have noticed that the imposed loads (uniform planar load on contour) have not been copied from floor to floor. Is there any way of copying these loads to other floors as the process of mapping out the loads on each floor is very time consuming?
Many Thanks
@jonpople Artur Kosakowski edited the topic from 'Copying Loads' for better findability and marked post as the solution. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution.
Solved by Artur.Kosakowski. Go to Solution.
Try to define this load in the different way.
The reason is that the contour this type of load is applied to is was not designed as an object type that can be selected and moved from one location to another.
