In a model I have the coordinates of the nodes with values of type X = 20.58888833 and Y=15.56559999.
The model is imported from Revit, why Revit fails to draw with a degree of accuracy of less? For example, X = 20.60 and Y = 15.55
Second question, in the same robot model if I run the automatic correction with precision = 0.01, after the model has the same coordinates.
You can correct the model automatically?
thanks
Solved by Rafal.Gaweda. Go to Solution.
Use this utility:
Use correction
or Generate Model with correct precision
The problem now is that the coating does not transmit the load. How do I fix this? thanks
Send us Revit model to check
Taka e look below at RST analytical model errors
Robot file with corrected geometry attached (my understanding how this should be done).
RST model correction
1. To unjoing wrongly connected columns from walls (marked on right hand sied on screen capture in previous post)
2. Walls can be corrected this way:
3. Beams
4 Braces : http://screencast.com/t/Sl1NhtJm
Corrected model http://www.4shared.com/file/HGHEme1r/Edificio_21a_v031.html
Thank you very much!!!!!
The video to correct braces me to a feature of Revit did not know.
You may also drag this nodes but sometimes Align works faster and better.
Hello!
I have a result file with the XYZ coordiantes of the nodes, like this:
Node # 9 ( X = 508.198, Y = 110.16, Z = -4052.31 )
Displaced Position : X = 508.198, Y = 110.16, Z = -4052.31
Displacement = DX: 0.000241976, DY: -0.000159354, DZ: -0.00506048, Magnitude: 0.00506877
Current Result Value: 5.068766307e-003 mm
I would like to know the XYZ coordinatey more accurate, so in a form like this:
Node # 9 ( X = 508.198XXXXX, Y = 110.16YYYYYY, Z = -4052.31ZZZZZZ )
Is it possible to change this accuracy?
BR.
Hello!
Sorry, I forgot to mention that I'm working in Multiphysics 2013.
Are these screenshots referring to it?
No, this is Robot forum.
