I have a model with a frame bearing on ground with 'rockbolts' installed at various locations. We have assumed the rockbolts take tension only (also lateral shear) and the compression is taken by soil bearing.
I am having some trouble with convergence of the model. I have attached 2 files, one files has the tension only supports at 'extreme' positions (converges) and the other file has them at the 'correct' positions.
I have also had issues with type 2 instabilities but these seem to have been resolved somewhere along my debugging trail.
I have set my non-linear parameters to update the matrix after each iteration as usual.
Any help would be appreciated.
Regards
Daniel
http://www.filemail.com/t/zhszhdhcuvpmgkj
Solved by Artur.Kosakowski. Go to Solution.
Try the settings as shown below:
