Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Control Perimeter for slab punching
4 REPLIES 4
stroxy
467 Views, 4 Replies
Hi
It appears the program is calculating a larger control perimeter for columns defined as edge columns than for columns defined as internal columns.  Am I missing something??
4 REPLIES 4
Artur.Kosakowski
in reply to: stroxy
Could you attach this rtd file please? Thank you.
Artur Kosakowski
stroxy
in reply to: Artur.Kosakowski
Hi Artur
File is attached.  By the way under ACI code there are no issues with punching.
Artur.Kosakowski
in reply to: stroxy
The algorithm for calculations of the critical perimeter has been optimized for columns which one of its local axes is perpendicular to the (nearest) edge of a slab. For the columns orientation (slab edge shape) as in your example this may be not 100% accurate. We will check if that could be improved. Thank you for indication this situation.
Artur Kosakowski
stroxy
Thanks Artur
