I want to create a connection between a continuous beam (IPE220) and a column(IPE270) welded in the middle of the beam.
The problem is that Robot creates the connection using the column continuous in stead of the beam.
How can I change it, to have the beam continuous and not the column?
Thank you in advance!
Solved by Artur.Kosakowski. Go to Solution.
Such connection type is not supported. It could have been created only if the vertical bar was rotated by 90 deg comparing to its current orientation.
Hello!
Thanks for your message!
It is a pity that Robot can't do this type of connection.
