Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Connection results not updated
2 REPLIES 2
dimogrec
433 Views, 2 Replies
Hi I'm running RSA Pro 2012 64bit on Win7 64bit and the connection results seem not to be updated. I mean that RSA displays (almost) always the first connection I calculate. Even if I change some parameters on the connection and recalculate the structure I steel got the results of the previous connection. Have a look at the attached video to understand the problem.
Restarting RSA sometimes works, but after one or two connection generation-calculation the issue turns up again.
thanks in advance
Tags (1)
2 REPLIES 2
Rafal.Gaweda
in reply to: dimogrec
Hi
Have you used before robot in greek language version ?
Rafal Gaweda
dimogrec
Hi Rafal thanks for responding
Yes, I've used it before in greek version. I've tried changing printout language in English (as you can see in the attached video working and printout language is English, regional settings Greek)
Lately I had the same problem with RSA pro 2011 (x32) but as far as I remember not always.. Also when the results remain "blocked" to a previous connection, exporting results to word/excel gives me a blank page with "results out of date. it's necessary to recalculate the structure"
No I have the latest sp installed (25.0.3.3833 (x64))
