When design connection per CM66, only double-angle type can be used in the column-to-beam connection? Why shear plate can not be selected?
Thank you!
CM66 shear plate connections are not available in Robot.
About double angle connection design, only shear force can be input in. The calculation cannot consider the axial force?
