Connecting nodes by a rigid link / bar element
3 REPLIES 3
ziegler123
2754 Views, 3 Replies
Hello
I have a small problem. Imagine this situation - when you have 2 shells with excentric center of gravity how can you connect the nodes from those 2 elements? I know that I can connect a high stifness beam element, but imagining a scenario where you would have a lot of nodes to connect - what would you do? A rigid link? And if so, how?
Here's a screenshot of an example with 2 excentric nodes connected by a beam element:
3 REPLIES 3
tony.ridley
in reply to: ziegler123
like this
tony
1. Define a rigid link between two nodes of separate panels
2. Select these nodes and copy them using the rotation command
The overlapped nodes created in the process will be merged during the model generation.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Thank you so much! You just saved me from hours of frustration 🙂
