I was just wondering if anybody could help with connecting a truss and a beam.
the beam is the support but im unsure how to connect the truss to it for calculations and results without having warnings.
the first time i done it the lines connected but the beam overlaped, therefore i set the beam to a lower value than the truss so that it could sit on top of it.
This still has 2 warnings because the two structures are not connected, i was wondering is there a function to connect these if so what is it and the process.
.. set the beam to a lower value than the truss
Then generate nodes along the beams below the corresponding nodes of the truss and connect them with either rigid links or dummy bars.
if i create rigid supports for the beam it overlaps the truss, and im unaware of dummy bars?
Please check:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Rafter-on-wall-problem/m-p/3363029
http://forums.autodesk.com/autodesk/attachments/autodesk/351/3242/1/5.jpg
sorry if you could can u give me a step by step instruction on how complete it if you manage it.
Thank you very much
Here you are.
