Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Message 1 of 9
693 Views, 8 Replies
Connecting Beam
I was just wondering if anybody could help with connecting a truss and a beam.
the beam is the support but im unsure how to connect the truss to it for calculations and results without having warnings.
the first time i done it the lines connected but the beam overlaped, therefore i set the beam to a lower value than the truss so that it could sit on top of it.
This still has 2 warnings because the two structures are not connected, i was wondering is there a function to connect these if so what is it and the process.
8 REPLIES 8
Message 2 of 9
Artur.Kosakowski
.. set the beam to a lower value than the truss
Then generate nodes along the beams below the corresponding nodes of the truss and connect them with either rigid links or dummy bars.
Artur Kosakowski
Message 3 of 9
in reply to: Artur.Kosakowski
if i create rigid supports for the beam it overlaps the truss, and im unaware of dummy bars?
Message 4 of 9
Artur.Kosakowski
Please check:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Rafter-on-wall-problem/m-p/3363029
http://forums.autodesk.com/autodesk/attachments/autodesk/351/3242/1/5.jpg
Artur Kosakowski
Message 5 of 9
Thanks dude but i must still be doing something wrong that aint working
Message 6 of 9
Artur.Kosakowski
Attach the file.
Artur Kosakowski
Message 7 of 9
Message 8 of 9
sorry if you could can u give me a step by step instruction on how complete it if you manage it.
Thank you very much
Message 9 of 9
Artur.Kosakowski
Here you are.
Artur Kosakowski
