The bar type for AS3600 is called up as 'f' in all of the beam and column results, not 'N'. Please change this in the next SP.
Tony
I'm not sure if I understand you correctly. Is it that you would like to see 2N16 instead of 2f16?
Implemented in Robot 2015.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
