I'm trying to model concrete flat slab and compare the results to results from different software. I fallowed all guidance I could find but it looks like I'm doing something wrong and my deflections are WAY to big. Can you please help? Where do I start?
Hello! I wonder if you could give me some more guidance please? Max deflection is only 15mm (and I know it should be 50mm ish). I run the design of reinforcement (got errors for punching shear) and had a look at long term conditions, stiffness factors etc. But the results are not correct. As I said I'm a beginner, tried to read manuals etc. but don't really know how to fix it. Will be grateful for your advice. And also I can't figure out how to manoeuvre Maps colour scale so that the results are easy to read (everything comes up in the same colour).
The map suggests that the deflection is 0 (has not been calculated). The [possible reasons:
1. No SLS cases used for RC Slab Required Reinforcement calculations
2. Check of deflection not marked in the reinforcement type assigned to the slab
3. Supports in all nodes of the slab so that it doesn't deflect (this happened more than one time in the models I received)
If none of the above I need the model to look at.
Czesc Artur!
1. First guess correct - didn't put any SLS for required reinforcement
2. Not to sure were to check
3. It deflects now 22mm so I don't think it's a case
As I said above, I'm getting 22mm deflection for long term conditions but it's still half of what is expected. Can you please have a look at the attached file? Thank you very much. I used 7zip as 'normal' zip wouldn't get it under 1.5Mb.
Sorry, my zip is more than 1.5Mb and when I use 7zip the file is not going trough, what can I do?
winrar to compress or www.wetransfer.com then paste the link to file in post
Looks like rar is not allowed extension (message comes up) and I can't use wetransfer (company policy). Is there any other way I can send it to you, please?
My colleague managed to compress the file even more. Please find attached and sorry for the confusion.
change rar extension (text) onto ra_ or zip or anything allowed
Please read: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/elastic-and-nonelastic-slab-deflection-verif...
That's brilliant! Thank you. Only when I run the design deflection is 42mm and not 52mm. I noticed that when running 'required reinforcement task' the message 'required types are not acribes to SLS combination, calculation may not be correct' comes up. Could that be the reason?
P.S. For some reason I can not open the attached link...
PLease update your version with Service Pack 5 for ARSA 2012.
SLS combinations for RC Desing should be SLS:QPR (quasipermanent) or SLS:FRE (frequent)
Thank you. Will change and check deflections again. Have a good weekend and I'm sure I will be back next week
Hello!
I'm trying to tidy the design - had to add some walls (linear supports) etc. While deflection is OK, moments are just way out of what I think they should be. Basically we've got the design done in different software... Could you please have a look at the attached and suggest where I went wrong again? And thank you very much for great support so far.
Pani Wioletto,
Troche wiecej szczegolow. Gdzie i czego Pani sie spodziewa, ktory przypadek itd...
Panie Rafale,
zestawilam przykladowe wyniki na zalaczonym pdf-ie. Grubosc plyty jest taka sama, obciazenia takze. Jak juz wczesniej napisalam ugiecia pod dlugotrwalym obciazeniem sa zblizone (53mm w Orion i 55mm w Robocie). Niestety momenty sa rozne. Nie za bardzo wiem jak do tego podejsc, bo analiza nie wykazuje zadnych bledow. Czy lokalne zageszczenie siatki na podporami 'wygladziloby' wykres momentow? No i w przesle roznica jest duza. Bardzo prosze o jakies sugestie i jeszcze raz dziekuje za pomoc.
Czy Orion to program MESowski czy tez liczy sie tam pasmo (np 1m szerokosci plyty) w analogii belkowej?
