I am looking for a way to report changes between different models of the same structure as the model develops.
For example, if load cases, member types, releases etc have changed between models.
I can print the 'report' from Robot including the input for the model. Then use something like winmerge to run a 'diff'. However this method is a bit messy.
Can Robot do something similar internally?
Thank you for your help
Solved by Rafal.Gaweda. Go to Solution.
