I have a problem with my macro. The command of projection in 3D doesn't work. My view stay in XZ plane.
robapp.Window.Activate
Set mavueRobot = robapp.Project.ViewMngr.CreateView(1)
mavueRobot.Projection = I_VP_3DXYZ
mavueRobot.Visible = True
mavueRobot.Redraw (True)
I want also make a capture of my model with diagram of results. Have you an example of code for it ?
I would like to get for final result the exemple in attachment.
Solved by Rafal.Gaweda. Go to Solution.
Ok but my PC is new and I don't have installed any Robot before. I have only installed RSA 2012.
To register it properly please open Command Prompt as Administrator, registsrer robot, check macro.
If it still does not work please respond to e-mail sent to yout from our system
@sorgjee wrote:Your EXACT code does not run due to a typo. Even without the typo, and using the rest of the code exactly as you've written, yes, it still crashes.
Even
It's the same for me. Robot crash when ask for better resolution.
I think it's because my computer is not enough speed. When I do some break in the macro it's working. What do I need in the computer ?
I'm in windows seven 64bit with ARSA 2012 and Office 2010
Use from time to time DoEvents
or pause code in some places. Pause function dos not exist in VBA so write your own function - example below
This function pauses code for 5 seconds
Sub Wait() waitTime = 5 Start = Timer While Timer < Start + waitTime DoEvents Wend End Sub
Is that possible to ask Robot : "W
@rg_Adsk wrote:Use from time to time DoEvents
hen the generation of the vue is finished, do something else" ?
View generation is one command \ line. After finishing it program steps to another code line.
@rg_Adsk wrote:View generation is one command \ line. After finishing it program steps to another code line.
So how explain that robot crash if I don't put sleeping times :
Sleep 33000 '33 secondes to generate a view of mobile loads
Sub cree_vues_resultats() If Not Robapp.Visible Then Set Robapp = Nothing MsgBox "Open Robot", vbOKOnly, "ERROR" Exit Sub End If fichier_sortie = Range("AE16").Value Dim mavueRobot As IRobotView3 ' this is important to set IRobotView3 if you want to make screen capture of this view Set mavueRobot = Robapp.Project.ViewMngr.GetView(1) ' it seems CreateView makes this strange affect, use GetView instead mavueRobot.ParamsDisplay.Set 68, False 'symbole charges ponctuelles mavueRobot.ParamsDisplay.Set 69, False 'symbole charges lineaires mavueRobot.ParamsDisplay.Set 70, False 'symbole charges surfaciques mavueRobot.Projection = I_VP_XY_3D 'mavueRobot.Projection = I_VP_3DXYZ mavueRobot.ParamsDisplay.Set I_VDA_OTHER_RULER, True Robapp.Project.ViewMngr.Refresh 'faire un zoom Sheets("Sommaire").Select transvfactor = Range("I32").Value transhfactor = Range("I31").Value zoomfactor = Range("I30").Value Call zoom_robot 'mavueRobot.Visible = True 'mavueRobot.Redraw (True) 'Robapp.Project.ViewMngr.Refresh 'MsgBox ("Regler la vue dans le modèle") Sheets("Sommaire").Select casprem = Range("N18").Value casder = Range("N19").Value prem_cas_roul = Range("N17").Value + 1 For i = casprem To casder Cas = i mavueRobot.ParamsFeMap.WithDescription = True mavueRobot.ParamsDisplay.Set I_VDA_SECTIONS_SYMBOLS, False If Range("I21").Value = "Myy +" Then mavueRobot.ParamsFeMap.CurrentResult = I_VFMRT_COMPLEX_REINFORCE_TOP_MYY sollicitation = "Moments Myy+" 'pour les charges roulantes attention If i >= prem_cas_roul Then Cas = prem_cas_roul + (casder - prem_cas_roul + 1) * 3 + ((i - prem_cas_roul) * 2 + 0) End If End If If Range("I21").Value = "Mxx +" Then mavueRobot.ParamsFeMap.CurrentResult = I_VFMRT_COMPLEX_REINFORCE_TOP_MXX sollicitation = "Moments Mxx+" 'pour les charges roulantes attention If i >= prem_cas_roul Then Cas = prem_cas_roul + (casder - prem_cas_roul + 1) * 3 + ((i - prem_cas_roul) * 2 + 0) End If End If If Range("I21").Value = "Myy -" Then mavueRobot.ParamsFeMap.CurrentResult = I_VFMRT_COMPLEX_REINFORCE_BOTTOM_MYY sollicitation = "Moments Myy-" 'pour les charges roulantes attention If i >= prem_cas_roul Then Cas = prem_cas_roul + (casder - prem_cas_roul + 1) * 3 + ((i - prem_cas_roul) * 2 + 1) End If End If If Range("I21").Value = "Mxx -" Then mavueRobot.ParamsFeMap.CurrentResult = I_VFMRT_COMPLEX_REINFORCE_BOTTOM_MXX sollicitation = "Moments Mxx-" 'pour les charges roulantes attention If i >= prem_cas_roul Then Cas = prem_cas_roul + (casder - prem_cas_roul + 1) * 3 + ((i - prem_cas_roul) * 2 + 1) End If End If mavueRobot.Selection.Get(I_OT_CASE).FromText (Cas) ' selecting case for results display ecran_capture = sollicitation & "_ Cas " & i mavueRobot.Redraw (0) Sleep 33000 '33 secondes to generate a view of mobile loads Robapp.Project.ViewMngr.Refresh Call screen_capture Next i 'saving printout \ report to file 'robapp.Project.PrintEngine.SaveReportToFile fichier_sortie, I_OFF_RTF_JPEG Robapp.Project.PrintEngine.SaveReportToFile fichier_sortie, I_OFF_RTF 'or directly opening printout in Word Robapp.Project.PrintEngine.ExternalPreviewReport EPF_MS_OFFICE 'MsgBox "QUITTER APPLICATION ROBOT" Sleep 10000 Robapp.Quit I_QO_DISCARD_CHANGES ' Quitter sans sauvegarde End Sub
send me whole your xls file and any other files required like mobile loads database etc.
Hi
I've got a problem with the scale in the view. It's not the good one I have to do the command normalize in Robot.
Is there a command in VBA API for this ?
Unfortunately you can not control scale on force normalization thru API.
I would like to select all "combinaisons" or all of "cas simples" but not both.
I test
mavueRobot.Selection.Get(I_OT_CASE).FromText ("Combinaisons") ' selecting case for results display
but it doesn't work,
Have you got a solution ?
Dim SimpleCaseSel As RobotSelection Dim ManualCombSel As RobotSelection Set SimpleCaseSel = RobApp.Project.Structure.Selections.CreatePredefined(I_PS_CASE_SIMPLE_CASES) Set ManualCombSel = RobApp.Project.Structure.Selections.CreatePredefined(I_PS_CASE_COMBINATIONS) mavueRobot.Selection.Get(I_OT_CASE).FromText (SimpleCaseSel.ToText) ' all simple case for results display 'or mavueRobot.Selection.Get(I_OT_CASE).FromText (ManualCombSel.ToText) ' all manual combinations for results display
I would like to add a fiew pages in my note like the attached file by macros VBA.
caracteristics
+nodes
+bars
+loads
+ Captures of views
Is that possible ?
caracteristics
+nodes
+bars
+loads
+ Captures of views
Is that possible ?
I guess you want to make screen captures of tables.
Create table, make screen capture of it, Example code below:
Dim Rtable As RobotTable Dim ScPar As RobotTableScreenCaptureParams Set ScPar = robapp.CmpntFactory.Create(I_CT_TABLE_SCREEN_CAPTURE_PARAMS) ScPar.Name = "Rtable" Set Rtable = robapp.Project.ViewMngr.CreateTable(I_TT_BARS, I_TDT_BAR) ' Rtable.AddColumn 1 - modify tables if you want by adding or removing columns Rtable.MakeScreenCapture ScPar
I've got a problem to export result view in a file (word or rtf)
and the header with word are not good :
Can you help me ?
If it is not sorted out by you please send me your macro.
My command
doesn't work any more.
Do you have a solution. I just want to save and quit the model.
robapp.Quit I_QO_SAVE_CHANGES
Sub robot_donnees() ' ouverture de robot, la session s'appellera robapp Set Robapp = New RobotApplication ' ce sera une structure de type panneaux Robapp.Project.New (I_PT_SHELL) If Range("I24").Value = "NON" Then Robapp.Visible = False Else Robapp.Visible = True End If If Range("I25").Value = "NON" Then Robapp.Interactive = False Else Robapp.Interactive = True End If If Range("I26").Value = "NON" Then Robapp.UserControl = False Else Robapp.UserControl = True End If Dim RetVal Sleep 1000 A = Range("AE2").Value affaire = Range("AE14").Value Robapp.Project.OpenExtFile A, I_EFF_STR, 1 ' Ouvre le fichier text se trouvant dans A Call initialisation_semelle Call Plaque_Robot ' MsgBox "Calcul terminé" 'robapp.Project.Close 'robapp.Quit = True 'Appuis entretoises 'Call appuis_robot Call charges Robapp.Project.CalcEngine.Calculate ' calculate model Dim mavueRobot As IRobotView3 ' this is important to set IRobotView3 if you want to make screen capture of this view Set mavueRobot = Robapp.Project.ViewMngr.GetView(1) 'Vue mise à jour mavueRobot.Projection = I_VP_3DXYZ mavueRobot.Redraw (True) mavueRobot.ParamsDisplay.SymbolSize = 2 'marche uniquement avec ROBOT 2012 Robapp.Project.ViewMngr.Refresh 'sauvegarde fichier robot sauv = affaire Robapp.Project.SaveToFormat I_PSF_RTD, sauv 'robapp.Project.SaveAs sauv Sheets("Sommaire").Select MsgBox "QUITTER APPLICATION ROBOT" Robapp.Quit I_QO_DISCARD_CHANGES ' Quitter sans sauvegarde End Sub
