Discussion Groups
Robot Structural Analysis
Active Contributor
sorgjee
Re: Command VBA Projection Capture of a view
01-10-2012 07:48 AM in reply to: Rafal.Gaweda
Hi Rafal,
Using the below command with Robot 12 and Excel 2007 causes excel to crash. Is this a known issue?
    ScPar.Resolution = I_VSCR_4096
Even
Please use plain text.
Product Support
01-11-2012 12:51 AM in reply to: sorgjee
It should work.
Public robapp As RobotApplication
Private Sub CommandButton1_Click()
Set robapp = New RobotApplication
Dim viewRobot As IRobotView3 ' this is important to set IRobotView3 if you want to make screen capture of this view
Set viewRobot = robapp.Project.ViewMngr.GetView(1)
viewRobot.Projection = I_VP_3DXYZ
viewRobot.Redraw (True)
robapp.Project.ViewMngr.Refresh
Call screen_capture
End Sub
Sub screen_capture()
Dim ScPar As RobotViewScreenCaptureParams
Set ScPar = robapp.CmpntFactory.Create(I_CT_VIEW_SCREEN_CAPTURE_PARAMS)
ScPar.Name = "capture"
ScPar.UpdateType = I_SCUT_CURRENT_VIEW
viewRobot.MakeScreenCapture ScPar
robapp.Project.PrintEngine.AddScToReport "capture"
End Sub
Try this (last post in this thread):
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/VBA-Excel-macro-for-any-object-geometry-modi...
Rafal Gaweda
Active Contributor
sorgjee
01-11-2012 01:22 AM in reply to: Rafal.Gaweda
Hi Rafal,
The macro you provided runs, but as soon as it comes to the Resolution command it causes excel to crash.
Product Support
01-11-2012 01:32 AM in reply to: sorgjee
Have you tried this ?:
Rafal Gaweda
Active Contributor
sorgjee
01-11-2012 04:08 AM in reply to: Rafal.Gaweda
Yes, makes no difference. Still crashing the exact same way.
Even
Product Support
01-11-2012 08:28 AM in reply to: sorgjee
What happens if you use diffeent screen capture resolution ?
ScPar.Resolution = I_VSCR_2048
or
ScPar.Resolution = I_VSCR_3072
Rafal Gaweda
Active Contributor
sorgjee
01-11-2012 08:30 AM in reply to: Rafal.Gaweda
Same crash for excel.
Product Support
01-11-2012 08:41 AM in reply to: Rafal.Gaweda
What is sisplayed after running this macro in Excell cells:
Private Sub Ver()
Dim robapp As RobotApplication
Cells(1, 1) = robapp.Version
Cells(2, 1) = robapp.ProgramVersion
End Sub
Rafal Gaweda
Active Contributor
sorgjee
01-11-2012 08:58 AM in reply to: Rafal.Gaweda
It comes out as:
12
25.0.3.3833
Product Support
01-12-2012 12:31 AM in reply to: sorgjee
Please try my EXACT code - published a few posts earlier.
Do not modify it.
I can see in your screen capture that in your screen_capture sub you create again robapp (which is already created by main function in my code)
Rafal Gaweda
