Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Combine two bars
5 REPLIES 5
2831 Views, 5 Replies
Combine two bars
Hi!
I want to delete a node and combine two bars for a single. How I can do?
5 REPLIES 5
Artur.Kosakowski
Open Bars table on the edit tab and replace origin/end node numbers of bars 9 and 10 (change from 13 to e.g. 2 for bar 9). The same can be don in the Inspector after selecting one of these bars. Mind to delete the 'excessive bar first.
Artur Kosakowski
Rafal.Gaweda
abudayev
in reply to: Artur.Kosakowski
Do you understand that the procedure you described is not combining/merging two bars. please add this function.
Rafal.Gaweda
in reply to: abudayev
abudayev
in reply to: Rafal.Gaweda
thank you!
