Discussion Groups
Robot Structural Analysis
andrea.pontiggia
Accepted Solution
Combination problem
158 Views, 5 Replies
02-11-2013 03:11 AM
I do not understand why the combinations are truncated with "......". (See image)
How can I see them entirely?
Another question.
If you use the "automatic simplified combinations", the generated combinations are not shown in the table. you can make them visible to be modified, as in the following image?
Andrea
Please use plain text.
Product Support
Artur.Kosakowski
Re: Combination problem
02-11-2013 03:18 AM in reply to: andrea.pontiggia
How long are these definitions? Try to make this field longer or increase its height.
The simplified code combinations are generated after calculations of the model. Then they should be displayed in the combination table. Their edition can be done when you convert them into the manual one.
Mind that you have to switch the display of the table from manual combinations to automatic combinations if both types exist in the model.
Artur Kosakowski
andrea.pontiggia
02-11-2013 05:19 AM in reply to: Artur.Kosakowski
"How long are these definitions? Try to make this field longer or increase its height."
I increased the width of the columns and the height but nothing changes. Is truncated to the last term.
"The simplified code combinations are generated after calculations of the model. Then they Should Be Displayed in the combination table". OK
"Their edition can be done when you finish convert them into the manual one."
How can i do?
"Mind That You have to switch the display of the table from manual to automatic combinations combinations if Both types exist in the model."
I did not understand
Andrea
Product Support
Artur.Kosakowski
02-11-2013 05:37 AM in reply to: andrea.pontiggia
See the attached picture.
Artur Kosakowski
andrea.pontiggia
02-12-2013 09:16 AM in reply to: Artur.Kosakowski
Sorry, I have another question. I did what you told me.
The generated combinations are not divided into SLS-CHR, SLS-QPR, etc., but they are only generic SLS.
Why is that?
tanks
Andrea
Product Support
Artur.Kosakowski
02-12-2013 11:48 PM in reply to: andrea.pontiggia
This depends on the regulation file(s) you used.
Artur Kosakowski
