Hi all
I am having a problem with a cross section of the column changes
this imange
http://nl0.upanh.com/b1.s29.d1/8e962d4a0d618a4cc785964418104722_44001610.col.bmp
I look forward to your help
thank all
yes good too
I thank you very much look forward to learning from you
you have sent me documents about robots ameliorated
my mail address:duchoatla@gmail.com
please anyone have a computational model of industrial frame
send me the reference
I sincerely thank
mail: duchoatla@gmail.com
Try to define horizontal offset at the top of the column. Mind that a bar element is just the line that represents the center of the section with assigned attributes such as profile type.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
The other option is just move the top node towards the middle of a frame. See the frame model attached to http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Design-colum-Steel-of-Robot/td-p/3562338 (message 10).
