Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Coefficient of homogeneity for concrete structure
3 REPLIES 3
andrea_pontiggia
491 Views, 3 Replies
I wanted to know if you can change the value of the coefficient of homogeneity n (or m), for the calculation of concrete structures.
thanks
Andrea
3 REPLIES 3
Which code and which point of the code do you mean please?
Artur Kosakowski
Italian Code NTC 2008 par. C4.1.2.2.5 " Nei casi in cui si ritenga possibile effettuare un'unica verifica indipendente dal tempo, si può assumere un coefficiente di omogeneizzazione n fra i moduli di elsticità di acciaio e calcestruzzo pari a 15."
Andrea
Assuming that you want to introduce this change to EC2 design that of RC elements available in Robot then this is not possible. The ratio is calculated based on properties of selected concrete grade and steel.
Artur Kosakowski
