I'm trying to add a live load with the subnature "crane" to the combination regulations.
But it's not working when I'm trying to generate the manual combinations. If I exclude this new type of live load the combinations is genereted but not if it's included.
Is it some limitation that makes it impossible to do this or am I doing something wrong?
Solved by HenkaCarlsson. Go to Solution.
and Nothing
try this :http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Sending-bigger-files/td-p/3795062
To be sure that you are loading correct regulation please change regulation name.
I did it and I see :
I did that and the it's working with the manual combinations but not with the manual combinations generated automatically. It would be a big help if that worked because it is a lot of combinations..
I redefined the loads as "Crane" loads, deleted the load groups and relations and redefined them and now it worked.
Thank you. 🙂
