There seems to be some inconsistency in the results between a member verification and a code group verification where the group only contains one member. See attached screenshots and calc. notes.
It looks like Robot for some reason changes the S275 material used in the member verification to some arbitrary material with a fy = 120 MPa in the code group verification.
Can someone explain if I’m doing something wrong here?
Solved by Artur.Kosakowski. Go to Solution.
Please make sure you have the correct material set in the group definition dialog.
Thank you for the quick response. That helped.
The code group was created through the API and apparently the material of the member is not set as default and you need to define it explicit.
Cheers
