Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Message 1 of 8
tord
1223 Views, 7 Replies
Cladding
Hello ARSA support
When I put a cladding at my construction it seems to be wrong load distribution.
See attached file.
Everything looks OK, but the beam 24 and 17 (in the lower part)
No load distributes to (41 42 43) and (11 12 25)?
/ Tord
7 REPLIES 7
Message 2 of 8
Artur.Kosakowski
in reply to: tord
Try to display loads generated automatically to verify the actual generation of loads.
Artur Kosakowski
Message 3 of 8
tord
in reply to: Artur.Kosakowski
Hello Artur
See attached PNG.
It shows that the loads don´t distributes to all of the beams.
/ Tord
Message 4 of 8
Artur.Kosakowski
in reply to: tord
Attach this model please.
Artur Kosakowski
Message 5 of 8
tord
Hello Artur
Here is the model.
See the two Lineloads with PZ-info (-5.7 & -8.2) outside the model at LoadCase "Nyttig Kat. C3"
They should be approx the same.(3,0 x 1,9 = 5,7)
/ Tord
Message 6 of 8
Artur.Kosakowski
in reply to: tord
This is going to be a stupid question but why want to have load applied to the edge beams when you set them as being ignored during load distribution? Smiley Happy
Artur Kosakowski
Message 7 of 8
tord
Hello Artur, that´s not a stupid question!
The beam is in fact a "wall", but I dident manage to set it like a wall. I got problem with the releases for the beams. And that is because I haven´t manage to fully understand the releases yet. I guess I was trying a lot of things before I gave up the walls.
Actually, I have put so much time to understand Robot, which is a very good program, but unfortunately without a good documentation.
I will try to investigate my problems better next time.
Thank´s Artur
(Do you have somthing good to read/see about releases - Please send it to me)
Message 8 of 8
Artur.Kosakowski
in reply to: tord
In such case you could either define a vertical panel or just supports instead of these beams.
This should not be that difficult. You can apply them only to beam's ends. By default all is fixed meaning you have transfer of bending as well as shear and axial forces. If you want to have one of these internal forces not to be transferred to other elements you define release marking the corresponding check box e.g. RY which means there is no MY bending moment transfer (pinned connection).
Artur Kosakowski
