Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Cladding Panels - Graphical Problem?
3 REPLIES 3
C.MacNicol
396 Views, 3 Replies
I am using cladding panels to define a one way spanning floor on to beams. Normally when I define the cladding panel it is displayed as a transparent panel, however occasionally it is shown as opaque. In some panels they are a mixture of the two! Screenshot attached showing the problem.
Is this likely to be just a graphical problem or an error with the panel definition? I thought maybe it was due to the plates being warped but on inspection of the contour coordinates all the nodes are in the same vertical plane.
Chris
3 REPLIES 3
Indeed this looks like it. Please try the solution proposed here
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/robot-software-program-error/m-p/3328987
Artur Kosakowski
C.MacNicol
in reply to: C.MacNicol
Unfortunately this does not seem to work. However if it does appear that this is only a graphical problem and not one which will affect the results then I think I can live with that.
rohitsarode22
Hello there!
Attached are 2 screen shots which visually show some gap between the cladding edge and B1 beam element.
Is this just a graphical error? I assume yes!
I tried applying some dummy load at end location of B2, seemingly it was getting transferred as I checked the shear force of the perpendicular beam B1.
To my surprise, I am able to measure the visually seen gap also, by measuring tool.
If I happen to intersect the members B1 and B2, I am amazed to see B1 moving visually to get connected to B2 exactly (though the end coordinates of B1 dont change!).
I have checked the load distribution graphically, things seem ok.
My next question - Is there any smarter way to make sure that cladding is connected to the adjoining beam exactly (or at least the beam ends-nodes) , rather than zooming in and falling prey to any graphical error.
If cladding is orthogonal with respect to global X and Y directions, it is easy. But my case is not orthogonal with respect to global X and Y directions.
Thanks!
