Cladding Load Distribution
3 REPLIES 3
SamKa85
425 Views, 3 Replies
I am new to RSA and 3D Analysis. So, I will be asking lots of questions 🙂
I  made a model of a canopy (in RSA 2010) that supports fabric on top. In order to simulate the action of the fabric in load distribution, I used claddings spanning between the two frames, specified the load distribution direction and applied a surface load on the cladding. The verification shows no error but the cladding is not working as no load is distributed to the steel frames.
Attached is the model I made.
I hope someone can help with this.
Regards
3 REPLIES 3
Artur.Kosakowski
in reply to: SamKa85
Claddings should be flat. Try to replace the single one you defined with number of straps that follow the divisions of arches into straight bars.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
SamKa85
in reply to: Artur.Kosakowski
Thank you for the prompt response.
I will try this and see if it works
SamKa85
It worked. Thank you
