Hi
Please find the attached file.
I designed beam177. According to drawing, in top there should be 2#25 (hooked right & left, with B=1.77m). I wish replace this with 4#25 bars (one end hooked, with B=2.5m).
How can I do these changes?
How can I check the capacity of the beam after these changes?
1. Switch to the detailed tab of the reinforcement table
2. Select one of these bars on the beam's view
3. Reinforcement > translate > mark Copy and create a new bar in the intended location
4. Repeat the same procedure for creation the 4th bar
5. Select all bars and change their lengths and the angles of hooks (set 0 deg) in the Inspector
6. Run Analysis > Verification
