Do I have to verify cracking with seismic combinations. The law is the Eurocode with attached French.
Robot apparent, subsequently cracking only (real armor) with SLS conditions and not with ACC.
How do I add also the combinations ACC checks relevant to the SLS?
thanks
Solved by Artur.Kosakowski. Go to Solution.
You can manually create such SLS combinations as shown on the attached picture.
Which part of EC2 or EC8 covers the calculations of cracks for earthquake situation?
It is actually a request from my client ...
I tried to do differently (see attached image), or changing the chart type combinations.
What do you think?
thanks
The way you assign the type of combination should not matter. This should work in the same way too.
