How can I use the job layout that I used in one project on another project? If I save as template I am unable to open from template on another project. I would like to make a default job layout for all jobs.
Solved by Rafal.Gaweda. Go to Solution.
Toolbars that are shown when I start Robot and how the layout of these are on the screen. E.g. I want the structure definition toolbar instead of the Structure model toolbar as default.
Hi, I think that's what you need (in russian):
http://www.rsa4all.com/2013/03/blog-post_15.html
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
Thanks Roman,
in short in english: template is saved for each structure type as *.rtt file - example path in Romanich blog
copy it from there to similar location on other computer.
