Discussion Groups
Robot Structural Analysis
Active Contributor
Change Node Numbers
1020 Views, 2 Replies
10-29-2012 05:26 AM
Is there any way to change the number assigned to a node? I have a spreadsheet designed to input all of my nodal data by cutting and pasting, but a couple of nodes are no longer correctly numbered for the spreadsheet and it mucks everything up.
For example i have a node numbered 86 in the model, with bars and properties attached, that i would like to be numbered 175. Is it possible without recreating the node and all the bars attached to it?
thanks!
Please use plain text.
Product Support
Re: Change Node Numbers
10-29-2012 05:38 AM in reply to: PaulGrimes2282
Rafal Gaweda
Active Contributor
10-29-2012 05:50 AM in reply to: Rafal.Gaweda
thanks!
