My name is Rodrigo. I'm developing a tool to analyze slab in shell finite element based in Baumann method through Robot Structural Analysis. To finalize my tool, I need to change the color of the finite elements according a fixed legend, but I didn't find a way to do this by API. The colors legend will show the reinforcement necessary in each element. Is this possible?
I´m waiting for an answer.
Best regards.
There is no option for assigning colors to surface elements. The workaround I can think of is to create panels with different thicknesses based on selection of surface elements in such a way that the thickness corresponds to particular value of reinforcement (you can name the thickness as values of area of reinforcement).
