When using the "Section definition" module , is there any mean to compute the tortional center of a section (group of walls for ex).
Please find attached a calculation note of a typical section of stairwell / lift... (without the information ime looking for )
Thank you
Solved by Pawel.Pulak. Go to Solution.
Torsion&shear center is calculated only when all segments (walls) are connected -see below:
Probably your walls are separated in points where you change their thickness.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
