Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Center of Gravity Coordinates
5 REPLIES 5
faisal.aaouatif
340 Views, 5 Replies
Goog Morning / Evening ;
Im getting different values of center of gravity coordinates of stories depending on load cases :
all static cases indicates the same value
all the sismic cases indicates the same value but different from value given under static loads.
please see attachement.
Thank you for help
5 REPLIES 5
Masses \ additional masses.
Rafal Gaweda
Thank you ;
Can you explain pleaseSmiley Happy
have defined no additionnal masses in the modal
all loads has been transformed to mass by using the load conversion to mass dialog box attached.
have i missed something ?
Thank you
Check this loads \ masses from them
Rafal Gaweda
Thank you Rafal
but im not sure i understand  what you mean.
Got your point.
Center of gravity presented for seismic cases should be the same as for Modal case, not as static ones.
Already corrected in version 2014.
Rafal Gaweda
