Goog Morning / Evening ;
Im getting different values of center of gravity coordinates of stories depending on load cases :
all static cases indicates the same value
all the sismic cases indicates the same value but different from value given under static loads.
please see attachement.
Thank you for help
Masses \ additional masses.
Thank you ;
Can you explain please
have defined no additionnal masses in the modal
all loads has been transformed to mass by using the load conversion to mass dialog box attached.
have i missed something ?
Thank you
Check this loads \ masses from them
Got your point.
Center of gravity presented for seismic cases should be the same as for Modal case, not as static ones.
Already corrected in version 2014.
