I just can't understand why if I tick or untick "cantilever" in the bar type, a very different value of delfection is taken into account (not the max limit)
Test is made on bar 335 and 312, bar type is "contre marche" and contre marche cons", detrimental comb : ELS/1.
Thanks guys.
Solved by t.sautierr. Go to Solution.
Problem solved : as the cantilever has got a negative curvature, the formula that Robot is using becomes false when it is a cantilever compared to a beam with two supports.
