I want to analysis CFRP (Carbon Fiber Reinforced Polymerq) bands in addition to my RC 5reinforced Concrete) model. For that I need to add a new material or change properties of an existing material. I tried to find a solution but I could not so am asking u guys to help me in this regard. Thanks
@Anonymous Artur Kosakowsk marked post as the solution. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution. i
Solved by Artur.Kosakowski. Go to Solution.
Job Preferences > Materials > press Modification button. Then type a new name, enter properties and press Add followed by OK. Finally restart Robot to make sure the new material is visible in all dialogs of the program.
ROBOT - Materials - How to create new materials
Hi @Anonymous
I just wanted to ask if you managed to define a new material following the steps I suggested?
And how can I swith to a different material on all my section bars and panels? I've already defined the new material but i'm looking for a way to change it quickly.
Thanks.
Select the desired material on the dropdown list ,then Select the bars you want to change material and click apply
Rafael Medeiros
