I've got a slab made up of several floor panels which I have successfully run reinforcement designs on before. I re-drew some of the panels and generated meshes succesfully, and run calculations, but when I try and run a 'provided reinforcement' design for the whole floor slab an error messgae comes up saying 'indicated objects must be lying in the same plane' . Does anyone know what this means and how to fix it?
Solved by Artur.Kosakowski. Go to Solution.
Please try to use Edit > detailed correct and adjust the structure to the single plane indicated by e.g. 3 corners of one of these panels.
Good evening. I followed the procedure and the error keeps popping. Is there another way to correct this?
Model link:
https://www.dropbox.com/s/r0r19owdpi4j00t/715-03-01-001_0_1320-M3-SR.rtd
Thank you.
