Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Calculating selected cases/combinations
3 REPLIES 3
bjornhgr
647 Views, 3 Replies
Hi.
I'd like to follow up on this thread about calculating single or selected load cases or combinations. Like the thread starter in the referenced thread, I have a bunch of load cases and several non-linear combinations (due to elastic soil and uplift).
I would really like to be able to calculate single or selected combinations without having to flag/unflag each and every combination as auxiliary cases. Is there really no way of doing this for multiple cases at a time? In the referenced thread, the solutions seems to be "Calculation restart", but with no previous calculations, I seem unable to use this option. Also, if cases are flagged as auxiliary, it doesn't help to mark them in the calculation restart dialog box.
Is there a way that, independent of the existence of  previous results, allows me to pick the cases and combinations I want to calculate without going through the unacceptably time consuming process of flagging/unflagging auxiliary cases?
Regards
Bear G.
3 REPLIES 3
Rafal.Gaweda
in reply to: bjornhgr
It works , movie: http://screencast.com/t/CBjmtkRG5Se
 This way: http://screencast.com/t/xvSJJnKxW
Rafal Gaweda
bjornhgr
in reply to: Rafal.Gaweda
Ah, brilliant. I never really took the time to realize what "operations on selections of cases" meant. My bad! Thanks a lot, you just saved me some time!:)
Regards
Bear G
gporrasm
Hello Rafal. I found this in the Robot Forum. The videos that you shared there are available but they seem to work with adobe Flash Player, and I don't have that. May you share them to be played in another player?
Thank yoy very much in advance
