My basic cable model has 7 load cases in which I have put into combinations. I had this warning come up in which I cannot determine the means. The results and reactions appear correct however I want to ensure I am not performing the analysis incorrectly. Thanks for the input.
Solved by Artur.Kosakowski. Go to Solution.
This message does not influence the results. To erase the request for code combination generation follow the steps indicated below:
