Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Cable Instabilities
4 REPLIES 4
331 Views, 4 Replies
Cable Instabilities
I have a relatively simple cable model which has a horizontal cable supporting a series of vertical cables.  I have split the horizontal cable into a chain of smaller elements so there are nodes at the connections between the horizontal and vertical cables.  The assembly case works fine, with just the dead load of the elements themselves.
I wish to apply horizontal (lateral) loads to the vertical cables which will react onto the horizontal cable.  Whenever I do this, I get an instability of type 1 in the global Y direction which I don't really understand how I can overcome.  I could understand a rotional instability but not a directional one.
Any ideas?
Can't attach File as .rtd extension is not allowed?!
Tom.
4 REPLIES 4
Discussion_Admin
Tom.
Try now. I just add the .rtd extension to the discussions.
Discussion_Admin
Artur.Kosakowski
If a rtd file is too large try to zip it first. Otherwise check http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Sending-bigger-files/td-p/3795062
Artur Kosakowski
Here is the file.
Tom.
Artur.Kosakowski
As far as I can see the instability is reported for case 2 in which there is no load defined. You have two options:
1. Delete case 2
2. Set  P-Delta analysis for case 2 (as done for case 1). In such case the case 2 will be just case 1 which is the assembly one.
Artur Kosakowski
