Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
CONCRETE TRACTION
10 REPLIES 10
Message 1 of 11
stm1A
439 Views, 10 Replies
CONCRETE TRACTION
REINFORCEMENT BEAM DESIGN
IS THERE A WAY TO NOT CONSIDER TRACTION IN CONCRETE IN SLS FOR THE STEEL TRACTION DIAGRAM:
PROBABLY IF THE BENDING MOMENT IS UNDER FLEXURAL LIMIT IN SLS, SECTION WORK WITH CONCRETE IN TRACTION.
thanks
stm
10 REPLIES 10
Message 2 of 11
Rafal.Gaweda
in reply to: stm1A
Could you be so kind and explain us what do you mean by that?
Preferable on some sketches, diagrams, screen shots...
Rafal Gaweda
Message 3 of 11
stm1A
in reply to: Rafal.Gaweda
 I have a 3 span (3m axis to axis) concrete beam 30x45 h.
10 kN load permanent
10 kN load variable
Mqpr (quasi permanent) is about 20 kNm
Area steel is 10cm2 superior, 10 cm2 inferior
in SLS Ats diagram give someting like 25 MPa for steel traction and the same for compression steel.
I would expect a tension in steel of 54 MPa
a compression in concrete of 1,77 MPa
a compression in steel of 18,71 MPa
thats the results of another program for concrete section.
the difference in tension is too much and more in robot compression steel=tension steel so i understand that all concrete section is working.
hope i explained situation
stm
Message 4 of 11
Rafal.Gaweda
in reply to: stm1A
Robot file please.
Rafal Gaweda
Message 5 of 11
stm1A
sent file to mailer@lithium.com
Message 6 of 11
Rafal.Gaweda
in reply to: stm1A
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Sending-bigger-files/td-p/3795062
-> "to generate link (if asked for e-mail address please use your e-mail address) and post only the link "
Rafal Gaweda
Message 7 of 11
stm1A
in reply to: stm1A
did u receive file?
Message 8 of 11
Rafal.Gaweda
in reply to: stm1A
Receive?
have you posted link ?
Rafal Gaweda
Message 9 of 11
stm1A
Message 10 of 11
Rafal.Gaweda
in reply to: stm1A
1.The file does not correspond to your description in posts.
2.Unfortunately due to one issue in rc design results display we are unable to check your model precisely.
Sorry for inconvenience.
Rafal Gaweda
Message 11 of 11
stm1A
can u explain it better please,
1)what exately the model do not correspond to my description? (you can easyly recreate the same model or another model : the importance is that quasy permanent moment is lower than concrete traction limit)
2) when you say there is a problem in robot do you mean that the program consider concrede traction under flexural limit moment?
Need steel diagram for my design report
stm
