C# API help v2
5 REPLIES 5
pipu123
716 Views, 5 Replies
C# API help v2
1)  How Rotate a bar
    Gamma for RobotBar
     //IRobotObjOperationType obrot = IRobotObjOperationType.I_OOT_ROTATE;
                    IRobotObjOperation obrot;
                    IRobotObjOperRotation rotacja;
                    rotacja.Angle 90;
      private IRobotApplication robApp;
      private RobotProjectPreferences ProjectPrefs;
      private RobotMeshParams MeshParams;
      private IRobotStructure str;
      private RobotLabelServer labels;
      private IRobotLabel label;
      private RobotSelection SelectionNodes;
      private RobotNodeSupportData footData;
      private RobotSectionDatabaseList steelSections;
      string StrSlup = "HEB 240";  // nazwy z odstępem
      string StrRygiel = "IPE 180";
      string StrScianaSrodek = "UPE 80";
      string StrScianaGora = "UPE 80";
      string klasaStal = "S355";
           robApp = new RobotApplicationClass();
           str = robApp.Project.Structure;
           labels = robApp.Project.Structure.Labels;
           IRobotLabel Section;
           IRobotBarSectionData SData;
           IRobotNodeServer inds = robApp.Project.Structure.Nodes;
           IRobotBarServer ibars = robApp.Project.Structure.Bars;
           RobotSelection iselSlup = robApp.Project.Structure.Selections.Create(IRobotObjectType.I_OT_BAR);
               inds.Create(1,0,0, 0);
               inds.Create(2, 5,5, 0);
               ibars.Create(1, 1, 2); //slup
               iselSlup.AddOne(1);
               ibars.SetLabel(iselSlup, IRobotLabelType.I_LT_MATERIAL, klasaStal);
               Section = robApp.Project.Structure.Labels.Create(IRobotLabelType.I_LT_BAR_SECTION, StrSlup);
               SData = (IRobotBarSectionData)Section.Data;
               SData.LoadFromDBase(StrSlup);
               robApp.Project.Structure.Labels.Store(Section);
               str.Bars.SetLabel(iselSlup, IRobotLabelType.I_LT_BAR_SECTION, StrSlup);
On a link “setting gamma using the API”  there is
IRobotBar bar;
Bar = …       please write this line using above code
bar.Gamma = 90;
 I don’t know how to add created bar  ibars.Create(1, 1, 2);   to IRobotBar method
2)    How to set local system as axis of a bar ( 3 points) ?
I want to set a local system   parallel to axis in a bar to do an offset for another bar
IRobotGeoCoordinateSystem.I_GCS_LOCAL_ORIGINAL;
3)
How to add all bars from construction
I would like    TempLato involves to all bars in a construction
 private IRobotStructure structure;
        RobotSimpleCase TempLato, TempZima;
            TempLato = structure.Cases.CreateSimple(7, "TmpLato", IRobotCaseNature.I_CN_TEMPERATURE,
                    IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR);
            TempLato.Records.New(IRobotLoadRecordType.I_LRT_BAR_THERMAL);
            LoadRecord = (RobotLoadRecord)TempLato.Records.Get(1);
            LoadRecord.SetValue(Convert.ToInt16(IRobotBarThermalRecordValues.I_BTRV_TX), obcTmpLato);
            LoadRecord.SetValue(Convert.ToInt16(IRobotBarThermalRecordValues.I_BTRV_TY), 0);
            LoadRecord.SetValue(Convert.ToInt16(IRobotBarThermalRecordValues.I_BTRV_TZ), 0);
4)      How to divide bar into “ n parts”
 number of segments :   4
Edit  divide    (division )
DivideBar (_bar_number : long, _div_points : IRobotValuesArray, _relative : bool) :
IRobotNumbersArray
5 REPLIES 5
pipu123
in reply to: pipu123
I am learning api c# for robot and I meet some difficulties. Please write a tip or solution.
Rafal.Gaweda
Ad 1
               int BarNumber = 2;
               ibars.Create(BarNumber, 1, 2); //slup
               iselSlup.AddOne(1);
               IRobotBar Bar = (IRobotBar)ibars.Get(BarNumber);
               Bar.Gamma = 12;
Rafal Gaweda
Rafal.Gaweda
LCS of bars is created automatically accordding to these rules:
http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/GUID-E6C19973-6864-4E67-9659-6F43579E2DB8.htm?highl...
You can rotate it around local X using   Bar.Gamma =
Rafal Gaweda
Rafal.Gaweda
3)
            IRobotStructure structure = robApp.Project.Structure;
            double obcTmpLato = 21;
            RobotLoadRecord LoadRecord = (RobotLoadRecord)TempLato.Records.Get(1);
            LoadRecord.Objects.AddText("wsz"); // in english replace string by "all"
Rafal Gaweda
Rafal.Gaweda
Example of dividing bar number 1 into 4 pieces by 3 points located 2,4,5 meters from the begining:
RobotValuesArray DivPoints = new RobotValuesArray();
RobotNumbersArray RobotNumberAr = new RobotNumbersArray();
robApp = new RobotApplication();
DivPoints.SetSize(3);
DivPoints.Set(1,2);
DivPoints.Set(2,4);
DivPoints.Set(3,5);
RobotNumberAr.SetSize(4);
int barnumber = 1;
RobotNumberAr = (RobotNumbersArray)robApp.Project.Structure.Edit.DivideBar(barnumber,DivPoints,false);
Rafal Gaweda
