Discussion Groups
Robot Structural Analysis
stroxy
Building Base Level
212 Views, 3 Replies
12-08-2011 09:09 PM
Hi, when assigning stories, does the building base level correspond to the bottom of all substructure elements i.e. basements, piles, foundations etc. or does it correspond to ground level i.e. location of building base shear?
Please use plain text.
Product Support
Rafal.Gaweda
Re: Building Base Level
12-09-2011 12:20 AM in reply to: stroxy
It is the lowest level from indicated by mouse or the level set by you manually
Rafal Gaweda
stroxy
12-09-2011 12:37 AM in reply to: Rafal.Gaweda
Still not quite clear.  In seismic design (building period determination), the height of the building is usually calculated as that above ground.  If I set my base level below ground, how will Robot calculate the building height
Product Support
Rafal.Gaweda
12-09-2011 12:46 AM in reply to: stroxy
The approach you describe is kind of manual approach.
Robot uses modal results (analytical) based on FEM model \ calculations where the defined supports are considered. Definition of ground level does not matter for these calculations .
Rafal Gaweda
