Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Brazilian codes in Autodesk Robot
73 REPLIES 73
Message 1 of 74
7042 Views, 73 Replies
Hello everybody.
The Brazilian codes (NBR 6118 for concrete, and NBR 8800 for steel) are not present in Robot. Is there a plan for them to be included?
What do you do when you’re working in projects for Brazil?
I’m sorry if this question has been answered before, but I did a search and found only one topic, that doesn’t directly answer this question.
Thank you all.
Ricardo Duarte, Eng.
73 REPLIES 73
Message 2 of 74
gustavo_c_vasconcellos
Hi Ricardo,
 I do the following:
- For steel, I use the US code
- For Concrete, I use the Eurocode but I changed the combination and I created a Brazilian rebar database, with 6,3mm, and 12,5mm, and removed 6,12, and 14.
If you need more infomation, please let me know.
Gustavo
Message 3 of 74
in reply to: gustavo_c_vasconcellos
Thank you Gustavo,
In the future, maybe I'll ask you again.
Are you Brazillian?
Thanks again.
Message 4 of 74
Rafacascudo
Now we are 3 🙂 Rafael
Rafael Medeiros
Message 5 of 74
in reply to: Rafacascudo
Hi Rafael,
Two and a Half! I'm Portuguese!
But, I'll be working in Brazil next month, so I hope to have your help!
Ricardo
Message 6 of 74
Rafael, temos mais um para brigar com a gente. Gustavo
Message 7 of 74
Seja bem vindo Ricardo!! Gustavo
Message 8 of 74
rogerscapini
Olá amigos,
Trabalho com estruturas há 10 anos, mas estou com grande dificuldade em aprender o programa por completa falta de referências (cases) e documentação.
Estou fazendo especialização em estruturas e estou interessado em fazer o meu TCC no Robot, mas sem referências é dificílimo.
Alguém interessado em me prestar consultoria remunerada?
Message 9 of 74
dennismjustino
Even using the American Steel codes, there are no metric steel profiles so we can use,
and it would be so much better if the brazilian code were avilable
Message 10 of 74
Rafacascudo
in reply to: rogerscapini
quais são suas duvidas?
Rafael Medeiros
Message 11 of 74
dennismjustino
Gostaria de saber se há uma biblioteca de perfis metálicos com unidades métricas,
ja que não consegui encontrar no software, e também se há uma previsão de
o programa estar habilitado às normas brasileiras.
E também não consegui achar um guia do usuário para o ARSA.
Grato
Message 12 of 74
Dennis,
eu tenho feito de duas maneiras;
1- usar os perfis Candenses (estão com a mesma identificação do Brasil)
2- Usar os perfil Americanos que estão com identificação diferente do Brasil e mudando-os apenas no desenho
O manual, bem fraquinho por sinal, você acha no site do Robot dentro da Autodesk.
Grato
Gustavo
Message 13 of 74
Olá,
Pelo que pesquisei, portanto, a solução mais fácil é usar o eurocode com algumas alterações para adaptá-lo à norma brasileira, é isso?
Grato!
Lucas
Message 14 of 74
Lucas,
para concreto eu uso o Eurocode com alguns ajustes quando necessário, para metálica eu uso a norma americana.
Grato
Gustavo
Message 15 of 74
thiathio
Alguma Novidade acerca da adequação às normas Brasileiras? Começei a estudar os programas da Autodesk para estruturas a fim de realizar um Artigo, mas comecei a pensar duas vezes devido a esses detalhes e faltas de experiencias e acervo brasileiro.
Any News about the brazilian Codes for RC in RSA. I've started studying the RSA but now i'll need to think two times.
How can i Procedure? People use Eurocode?
Gabriel Chiachio -
Universidade Federal da Bahia
Message 16 of 74
rogerscapini
in reply to: thiathio
Yes I think you really need to think twice. It seems that the brazilian RC codes are not important to Autodesk. If you are an engineer know you cannot use any other codes in brazilian territory, otherwise you could be persecuted if some problem occurs.
You meat how you should proceed. I'll tell you: Do not use RSA until Autodesk begin to honour our RC code as have been done to other countries even smaller.
RSA is a great program, but it is very frustating the fact that we brazilians are not respected. Translating the system is not sufficient, guys!
Roger
Message 17 of 74
rogerscapini
sorry, I wrote meat intead of meant.
Message 18 of 74
Dear Brazilians,
I do the following:
I use the Eurocode with Brazilian rebars (I included 6.3 and 12.5mm) and edited the load combinations to be exactly as Brazilian's code.
I believe that the main difference is on the drawings shapes, therefore, I chose the Italian shapes as my default shape and edited the anchorage length to be as our code requirement.
The hardest part, in my opinion, is to model the analytical model in Revit before send to Robot.
I agree that Autodesk should include the Brazilian code, it is not difficult to do because our code is very, very similar to the Eurocode.
Gustavo
Message 19 of 74
Olá.
Gostaria de sabber, se é possível efetuar o uso de API para a elaboração de procedimentos de calculo dentro do Robot. Minha dúvida é a seguinte: após o calculo da estrutura eu consigo elaborar rotinas para o dimensionamento de um elemento dentro das normas brasileiras (uma viga de concreto por exemplo), que eu mesmo estarei criando.
Questiono isso pelo fato deste topico tratar sobre as normas basileira estarem adaptadas com o uso de normas estrangeiras.
Obrigado.
Raphael.
Message 20 of 74
Rafacascudo
in reply to: rspozito
Raphael, certamente sim , mas não sei se igual ,com todos os recursos que teria se fosse nativo do programa(RSA).
Coloque sua pergunta em inglês para obter uma resposta oficial dos especialistas de suporte do Robot
Rafael Medeiros
