Hi All,
may be a stupid question but:
How I can use the Boolean operators in a building type structure ?:
In the example file of the ICK the Boolean operators are available despite the structure file type. This not happen in my case:
Why ?
Solved by Pawel.Pulak. Go to Solution.
by default Boolean operations are not available in Building Design type of structure to simplify the interface and because these commands are ussually not used there.
If necessary you can use Tools>Customize>Customize Menu to add them in Edit menu. See the attached screen capture.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
