Discussion Groups
Robot Structural Analysis
StuartRogers
Accepted Solution
Beam design with THA
567 Views, 4 Replies
10-15-2012 02:44 AM
I'm currently trying to carry out a beam design / verification for a THA analysis.
The analysis is a simple steel structure, modelled using beam (bar) elements.
I have tried to use the THA + and THA - load cases. These are created automatically when the THA analysis is run. Unfortunately when I select them in the 'Steel/Aluminium Design' -> Calculations -> Loads -> Cases dialogue box, they do not appear.
I have also tried creating a load case for each timestep of the THA, then running the member (or code group) verification for these timesteps. This takes a very long time to run. Also unfortuantely so far this has returned zero loading on the members when the design / verification is run.
From the 'Diagrams for bars' view, I can see that there are moments and forces in the beams.
Is there a tutorial available for doing beam design from a THA or please can you advice me what I might be doing wrong.
Thank you for your help.
Regards
Stuart
Please use plain text.
Product Support
Artur.Kosakowski
Re: Beam design with THA
10-15-2012 02:53 AM in reply to: StuartRogers
The design should be run against the simple load cases (or combinations which include them) created from the conversion of THA time steps results.
Artur Kosakowski
StuartRogers
10-15-2012 04:56 AM in reply to: Artur.Kosakowski
Arthur,
Thank you for your advice.
I am still seeing 0.000 ratios for the simple load cases converted from the THA. Infact I now get a ration of 0.000 for all of the load cases.
However, there is loading going through these members (according to the 'Results'-> 'Diagrams for bars' output - see the attached screenshots for further info.
Is there something that I could be going wrong?
Thanks again for your help.
Stuart
Product Support
Artur.Kosakowski
10-15-2012 05:06 AM in reply to: StuartRogers
Could you send me the file to look at?
Artur Kosakowski
StuartRogers
10-15-2012 06:02 AM in reply to: Artur.Kosakowski
I did a few things and now it works. Not sure which was the solution.
1. I saved the file as a new name
2. Moved the initial load for the THA to a loadcase number lower than the THA loadcase number
3. The spectral analyses has somehow been deleted, so I added them again. I didn't think the Spectral analyses would be used for the THA.
The member design is now working fine.
Stuart
