Hello, How do I set my reinforcement pattern in the beam design module to only generate hooks at the extreme end supports?
Solved by jad.dellel. Go to Solution.
Hi Stroxy!
Which Rc code do you use ?
Hooks are generated on both ends of the bar. I only want the hooks at the extreme supports and a regular lap splice (no hooks) within the span
Can you upload your rtd file please?
Stroxy, can you send us only your RC beam?
The file you attached before contains all the model without any RC beam calculated.
Stroxy,
It should work as you excpect if you Switch to single span
Stroxy,
Please download and install SP1 for Robot 2014 which includes some improvements in that area.
